[BOTH] Battle Report Supply Lines - Partida Vías de Suministro
Escenarios & Reportes De Batalla
Post by ajmendoza » Mon Jun 11, 2018 6:39 pm
Hello all!
Another game last week (which was played by a new community member (helped by myself) in one side and Oliver - Hida Tomaru -, Buke Daimyo). Thanks to Club Comandante for letting us play there.
We played the Supply Line scenario with 400 army points armies and it was really fun. The battle was good for the Samurai from the beginning, in the second turn there was already two caravans burned down. But some heroic actions on the sohei side and some good strategic decisions made the third caravan leave the table against the odds. The buke won anyway, but it was a really fun game and our brains were really due the activation system (who did it? :P) there was sooooo many decisions to take and it was easy to destroy your own strategy.
(sorry for the pictures quality.. I should fix it)
Deploy. Sohei left and Buke right. The caravans must cross the table moving 15 cm + 3D6 at the beginning of each turn.
Buke army
Yari ashigaru unit (15 miniatures)
Samurai Katana unit (5)
Ashigaru Yumi (archers) (5)
O-ban heavy cavalry (4)
Samurai Cavalry with Katana (3)
Several heroes (mounted and unmounted)
Sohei army
2 monk with naginata units (10 miniature each)
Heishi unit (10)
Monks with teppo (5)
Ama Kihei cavalry (5)
The Buke general used a special command order which allowed him perform an extra move during the deployment. Thanks to that in the first turn two of his units could move and burn down two caravans. The sohei run trying reach the close combat and stopped the rest of the units. The Ama Kihei (sohei elite cavalry) calculated wrongly and they put themselves in range for the heavy cavalry Buke O-ban charge. And so did them and almost destroyed the sohei cavalry and killed the hero which was leading the unit. This cavalry was the elite of the army so the center of the sohei army was very compromised.
The O-Ban cavalry showed why they have the "Terror" ability. So tough when charging!
The charge was brutal, killed the hero and decimated the unit, but those nuns stood in close combat.
The third caravan move just in front of the ashigaru buke unit, they did not have even to move. The sohei player got the initiative thanks to a command duel and the hero sohei general jumped over the caravan in order to put himself in front of the unit, engaging them in hand to hand combat (paying with his life). This way the ashigaru could not move this turn and the caravan would be abler to move again (cavalry cannot interact with mission objectives). The monk unit move forward and stood against a the second cavalry buke unit.
In the right flank the buke were taking positions to wait for the caravan, but they commit a mistake when did not blocked the road. Two sohei units moved up to the border of the path forming a near corridor to let the caravan cross them.
And so it did, but the hungry samurai charged against the heishi sohei and destroyed the whole unit in just one charge, although they received several casualties.
There was an archer ashigaru buke unit in the buke's left flank. After commit several casualties in the monk unit in previous turns, they moved to assault the caravan, but a sohei teppo unit, which have had nothing until this time, killed most of the unit. Surprisingly, the ashigaru did not flee and it has an opportunity to stop the caravan.
But he did not and the caravan left the table in the 5 (and last) turn.
This is the end. One caravan scaped but other two were burned, Buke won widely. He also has a secondary mission (kept in secret until the end) of kill as many heroes as possible, and he killed a lot.
Both sides suffered many casualties but the sohei army was almost destroyed. The Buke army is soooo strong thanks to their armour. Definitely I have to add as many ranged combat units as possible.
This game had a lot of fun and many many strategical decisions. Many things happened during the game (that sohei hero stopping an the ashigaru yari unit was quite epic). We did many things good and wrong, and that is what is so interesting of these miniature wargames.
hope you enjoy it!
Re: [BOTH] Battle Report Supply Lines - Partida Vías de Suministro
Post by ajmendoza » Mon Jun 11, 2018 7:14 pm
((spanish version))
Hola a todos!
Otra partida de la semana pasada que fue jugada por Oliver como comandante Buke y por un nuevo miembro de la comunidad (ayudado por mi) que utilizaba mis sohei. Gracias al Club Comandante por dejarnos jugar allí.
Jugamos el escenario de batalla "Líneas de suministro" con ejércitos de 400 puntos y fue muuuy divertido. La batalla fue bien para los samurai desde el principio, en el segundo turno ya tenian dos de los tres carromatos quemados. Pero algunas acciones heróicas por parte de los sohei y algunas decisiones estratégicas bien tomadas permitieron al tercer carromato contra toda espectativa, aunque el jugador buke ganó de toda forma. Como digo fue una partida muy divertida y nuestros cerebros estaban a tope por culpa del sistema de activaciones (quien lo hizo?! maldito!), hubo muuuuuuuuchas decisiones que tomar durante la partida.
(perdonad por la calidad de las fotos, tengo que arreglar eso).
Despliegue. Sohei a la izquierda y Buke a la derecha. Los carromatos tienen que cruzar la mesa moviendo 15 cm + 3D6 al principio de cada turno. 5 turnos máximo.
Ejército Buke
Yari ashigaru (15 miniaturas)
Samurai Katana (5)
Ashigaru Yumi (arqueros) (5)
O-ban caballeria pesada (4)
Samurai Cavalry con Katana (3)
Varios heroes (a pie y a caballo)
Ejército Sohei
2 unidades de monjes con naginata (10 miniaturas cada una)
Heishi (10)
Monjes con teppo (5)
Caballeríá Ama Kihei (5)
Varios héoes (a pie y a caballo)
El general buke usó una orden de comandante especial que le permitió mover durante el despliegue dos de sus unidades. Eso le hizo posicionarse lo suficientemente cerca como para fácilmente mover y quemar, en el primer turno, dos de los carromatos. Los sohei intentaron correr para hacer de pantalla con sus cuerpos. La caballeria Ama Kihei calculó mal y se puso a distancia de carga de la caballería pesada buke O-ban. Y cargaron y prácticamente destruyeron la unidad, matando a la héroe que las lideraba. Esta caballería era la élite del ejército de monjes, por lo que el centro de este ejército se vió muy comprometido.
La caballería O-Ban demostró el por qué tienen ese "Terror" como habilidad. ¡Son muy duros cuando cargan!
/align]
La carga fue brutal, matando a la heroina a caballo y diezmando a la unidad, aunque esas monjas se mantuvieron en el combate.
El tercer carromato movió hasta colocarse en frente de la unidad buke de ashigarus con lanza. No tenian ni que moverse para echarla a arder! El jugador sohei utilizó un duelo de mando para robar la iniciativa al principio del turno y el héroe general sohei saltó a través del carromato para interponerse entre los ashigaru y la caravana, dándole tiempo a ésta para escapar pero pagando el valor con su propia vida. Al entrar en combate cuerpo a cuerpo con el héoe, los ashigaru no pideron más que combatir. La unidad de monjes del flanco izquiero se adelantó para aguantar una carga de la caballería buke con katana, que les hizo mucho daño, pero les impidió seguir avanzando (la caballería no puede interactuar con objetivos de la misión).
En el flanco derecho sohei, los buke estaban moviendose para coger posiciones y esperar al carromato, pero cometieron el error de no bloquear el camino. Las dos unidades sohei del ese flanco se colocaron en el lidne del camino dejando un pasillo estrecho por donde el carromato podría pasar y ellos bloquearían a las unidades que quisiesen perseguirlo.
Y así lo hizo, pasó entre las unidades en el cuarto turno. Los enfadados samurai cargaron contra la unidad de heishi que no aguantó y fue completamente destruida por la dureza de las katanas, aunque los samurai recibieron numersas bajas.
La unidad de arqueros buke se acercó al camino para intentar interceptar el carromato en el último turno, pero la unidad de sohei con teppo, que hasta ese momento no habia hecho nada, descargó fuego sobre ellos arrasando a casi toda la unidad. La única miniatura que quedó, milagrosamente, no huyó e se mantivo ahí para cumplir su misión.
Pero no pudo hacerlo. El movimiento del carromato en el último turno fue muy largo y consiguió escapar milagrosamente.
Este es el final. Una carromato escapó y dos fueros quemandos. El general buke ganó ampliamente además de por esto porque tenía como misión secundaria (en secreto hasta el final) matar tantos héroes enemigos como fuese posible... y mató a muchos.
Ambos bandos sufrieron muchas bajas pero los sohei fueron prácticamente destruidos. El ejército buke es muy duro gracias a sus armaduras, por lo que la próxima vez tengo que añadir tantas armas de larga distancia como sea posible.
Esta partida fue muy divertida y se tomaron muchas decisiones de gran peso estratégico. Muchas cosas pasaron durante el juego e hicimos muchas cosas bien y mal debido a la presión, que es lo que hace interesante a estos wargames con miniaturas.
¡Espero que os haya gustado!
DavidCE
Post by DavidCE » Mon Jun 11, 2018 7:46 pm
Que bien se ve esa mesa!
七転び八起き
Nana korobi ya oki
Fall down seven times, stand up eight
Satori
Post by Satori » Tue Jun 12, 2018 7:48 pm
Espero poder quedar un dia con vosotros para disfrutar de este juego juntos^^
"El camino del samurái se encuentra en la muerte"
Post by ajmendoza » Wed Jun 13, 2018 9:01 am
Pues estaba pendiente de hablar con e-minis para avisaros y ver si os venía bien. Me dijo Javi que si hacíamos unas demos en la tienda ¿qué tal sería vernos allí para probar el juego?
Satori
Post by Satori » Wed Jun 13, 2018 9:04 am
por mi encantado, ya hablamos para quedar^^
Bawon Samdi
Post by Bawon Samdi » Thu Jun 14, 2018 7:18 am
Awesome pictures. The two armies look really great.
Post by ajmendoza » Fri Jun 15, 2018 9:42 pm
Thanks!
Users browsing this forum: No registered users and 4 guests
